laburtons
Aug 25, 2020Follower
RN10441D - OS 10.6.3 - After Factory Reset, no apps loaded and also cannot manually install apps
After having a two diskdrive failure, I have installed four new 2tb harddrives in my RAID storage (RN10441D). I also did a factory restore and then followed the instructions to update the OS to 10.6...
JohnCM_S
Aug 28, 2020NETGEAR Employee Retired
Hi laburtons,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
