dimistat71
Jul 19, 2014Aspirant
ssh #23563342
How can i gain access at the operating system? I am trying to install your adds (bin or deb),but i cannot reach the console of the O.S. I tried ssh and i get wrong password (root and admin password ...
Jul 20, 2014Guru - Experienced User
You can enable ssh via system->settings (its listed under "services").
Then use something like putty to connect to the NAS. Login is "root", the initial password is the same as the admin password.
