Equinox1's avatar
Apr 14, 2016
Transmission crashing after a couple of seconds
I've had the canonical Transmission plug-in installed on OS6 for months (the 3.0.8 that you install from the UI). Yesterday I noticed that there is a newer version on super_poussin dropbox, so I tried to installed. I got the message that it installed fine, but then it disappeared from the installed app list.
After a few cycles of installing and uninstalling, I had a look to the log file, and I noticed that the transmission daemon is getting killed and revived every couple of seconds. When it goes does, this is the message in the log:
Messagetraps: transmission-da[24271] trap invalid opcode ip:42905c sp:7fc8c199ac20 error:0 in transmission-daemon[400000+6b000]
Any ideas on what this could be, and how to reset the whole thing?
  • yep now  install the transmission interface package :) (also in my dropbox)
    • Equinox1's avatar
      Equinox1
      Guide
      I'm using this one "transmission_2.92-1_amd64.deb" from the dropbox all along....
      • Equinox1's avatar
        Equinox1
        Guide
        Ah... I see you updated it just now. Let me try the new one. then. :)
ProSupport for Business
