Newsat11
Apr 22, 2016Luminary
Uninstalling MySQL or resetting to default settings (advanced question)
I'm trying to install an application that is dependent on the MySQL server. I was installing some other programs and for security reasons I changed the password setting for the server to be able to a...
- Apr 23, 2016
Hello Newsat11,
Thanks for replying. You may close this by clicking Accept Solution probably to the response you made since that I believe has the solution you took.
We appreciate your contribution to the community, please feel free to post anything that you think worth sharing and questions you want to ask.
JennC
Apr 23, 2016NETGEAR Employee Retired
Hello Newsat11,
I believe that is something you can do by accessing it through SSH, no idea of the commands to use. Maybe send PM to author/developer.
