Newsat11
Apr 22, 2016Luminary
Uninstalling MySQL or resetting to default settings (advanced question)
I'm trying to install an application that is dependent on the MySQL server. I was installing some other programs and for security reasons I changed the password setting for the server to be able to a...
- Apr 23, 2016
Hello Newsat11,
Thanks for replying. You may close this by clicking Accept Solution probably to the response you made since that I believe has the solution you took.
We appreciate your contribution to the community, please feel free to post anything that you think worth sharing and questions you want to ask.
JennC
Apr 23, 2016NETGEAR Employee Retired
Hello Newsat11,
I believe that is something you can do by accessing it through SSH, no idea of the commands to use. Maybe send PM to author/developer.
Newsat11
Apr 23, 2016Luminary
Thanks for the response, I ended up just restoring the unit to factory defaults to restore the settings. I had my data backed up so it wasn't a big deal. I know deleting the files would be through SSH, and I know the commands, I just don't know where the files are located. I don't know if there is anyone on the forums that could tell me. I know you need to delete the libraries in etc, the app data in apps, but I don't know where the databases are stored. I'm going to close this thread because I think this might be a little too advanced for a forum, I would need someone familiar with the installation path of the application.
- JennCApr 23, 2016NETGEAR Employee Retired
Hello Newsat11,
- mdgm-ntgrApr 25, 2016NETGEAR Employee Retired
You would need to use the mysql command to set the password.
The location where the MySQL databases are stored could be e.g. /var/lib/mysql - bilaridisJul 22, 2017Aspirant
I would like to help me to reset password for mysql ...
I have the readynas 21200
thanks vasilis
