gaetan
Jan 27, 2012Aspirant
-16443401 Mo (-3565%) of 450 Go used
Hi,
My RedyNas NVX is reporting funny figures regarding disk space.
Both 500 GB disks (X-RAID2) - no errors reported.
Model: ReadyNAS NVX Business Edition [X-RAID2]
Firmware: RAIDiator 4.2.19
Memory: 1024 MB [6-6-6-24 DDR2]
Volume C: Online, X-RAID2, 2 disks, -3565% of 450 GB used
Thanks
GL
Thanks
GL
- OOM-9NETGEAR ExpertThat sounds quite odd.
You should send the logs, so we can look at it.
http://www.readynas.com/kb/faq/misc/how ... d_all_logs - gaetanAspirantThanks for the suggestion. Log files sent. Regards.
- OOM-9NETGEAR ExpertI am going to check with someone to see if they are able to look at the logs to find the core issue. It sounds like there might be something with the file system.
Are you able to access your data okay? - OOM-9NETGEAR ExpertRestart w/ a volume scan. LV looks fine as well as the RAID and dumpe2fs.
Maybe a filesystem check will correct it out. - gaetanAspirantOk, I am now rebooting it and running scans ...
I did get an error message this morning when logging on to the web interface.
"ATA error count has increased in the last day. Disk 2: Previous count: 5 Current count: 6 Growinf SMART error indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk."
Gaëtan - gaetanAspirantOk, rebooting and scanning seems to have sorted the issue.
***** File system check performed at Sat Jan 28 10:02:18 WET 2012 *****
fsck 1.41.14 (22-Dec-2010)
e2fsck 1.41.14 (22-Dec-2010)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/c/c: 262386/7393280 files (32.4% non-contiguous), 85615484/118292480 blocks
Volume C: Online, X-RAID2, 2 disks, 72% of 450 GB used
Many thanks for the suggestion.
May I ask another quick question ?
At the moment, I have 2 disk of 500 Go ...
Can you please confirm that if I want to expand the storage space, I have 2 solutions:
1- addind a third (or fourth, fifth ..) hard drive of the same capacity in order to expand storage space.
or
2- remove one of the 2 500Go disks - then add for exemple a 1To hd, wait for data to be copied ... reboot ReadyNas in order to expand free space, then replace the other 500Go disk leave by another one of 1To
Thanks
Gaëtan - StephenBGuru - Experienced User
Basically yes. But not 100% right,gaetan wrote: ...
or
-With option 1, you could add 1 TB drives, you are not limited to 500 GB.
-With option 2, there is no expansion until you install the second 1 TB drive. With normal single-redundancy, the capacity of the array is the total minus the largest.
If you are happy with single redundancy, then it is cheaper (per GB) to fill the empty slots first. Of course that assumes your existing drives are not failing.
If you are considering dual redundancy in the future (ultra/pro supports this, not sure about nvx), then add a third 1TB drive, then after expansion completes replace one of the initial two with a second 1 TB drive. That leaves an empty slot for the future dual-redundancy drive - mdgm-ntgrNETGEAR Employee RetiredOnly 6-bay or greater models support dual-redundancy.
