wquatan
Aug 13, 2013Aspirant
102/104 Win Compatibility
I'm thinking about purchasing 102/104 but have some questions for which I couldn't find an answer. - why is Windows compatibility specified as Vista onwards ? I can't imagine older Windows versions...
mdgm-ntgr
Aug 13, 2013NETGEAR Employee Retired
wquatan wrote:
- why is Windows compatibility specified as Vista onwards ? I can't imagine older Windows versions (2000 XP ...) can't access/use the NAS ? What's the reason for that ?
Windows XP is approaching the point where Microsoft no longer provides security updates for it. It is time to move on. Whilst they may work with the NAS NetGear can't support using the NAS with PCs running every version of every operating system.
wquatan wrote:
- suppose I have two 102. Can I , without any risks , put the disks from one 102 in the other one (in case of 102 hardware failure) ?
If the disks are fine, yes. Best to install the same firmware on both 102 units. However you should of course ensure you have an up to date backup. Disk failure is far more likely than the NAS chassis failing
Also don't forget the 102 has a 3 year warranty
