doubleplouc
Dec 17, 2012Aspirant
2.5" HDD ?
Hello, It looks like I cannot search in the forum with 2.5" (it change my search in '2 5' instead of '2.5"'). Did anyone used 2.5" HDD in readynas ? if yes, could you share which readynas and w...
Dec 17, 2012Guru - Experienced User
Mechanically an adapter like that looks like would work. You can't use an enclosure that doesn't bring the sata and power connectors to the standard positions for 3.5" drive.
Whether it is a good idea (or would be really compatible) is another question.
Are you thinking about using SSD? I've seen one post from someone who did that with apparent success, but I've never seen a followup. I doubt that the NAS firmware supports TRIM.
