doubleplouc
Dec 17, 2012Aspirant
2.5" HDD ?
Hello, It looks like I cannot search in the forum with 2.5" (it change my search in '2 5' instead of '2.5"'). Did anyone used 2.5" HDD in readynas ? if yes, could you share which readynas and w...
mdgm-ntgr
Dec 17, 2012NETGEAR Employee Retired
One of the things the NAS uses to control the fan speed is hard disk temps. Also the NAS uses SMART values to help detect some pending disk failures before they happen. So if it sees a disk temp of zero it probably thinks the SSD is failing/dead. The NAS is not programmed to handle differences between hard disks and SSDs.
