veehexx
Aug 24, 2010Aspirant
2.5" hdd
i've just bought a new hdd for a laptop, and looking at it's spec - http://www.wdc.com/en/products/products.asp?driveid=685, it seems a 1tb drive is also available - i find this interesting! obviou...
mangrove
Jun 17, 2012Apprentice
Bumping this old thread with info about how to do it for free, and easily too... basically the holes in the 2.5" disk aligns perfectly outside the tray, and with one of the large holes in the tray. You'll have to cut out a tiny bit to use all four mounting holes, though.
http://www.magnuswedberg.com/index.php?doc=2_5_inch_disks_in_a_Netgear_Readynas
I did this because I had a 500GB laptop drive around. Also, I like to tinker.
