veehexx
Aug 24, 2010Aspirant
2.5" hdd
i've just bought a new hdd for a laptop, and looking at it's spec - http://www.wdc.com/en/products/products.asp?driveid=685, it seems a 1tb drive is also available - i find this interesting! obviou...
emoacht
Jun 17, 2012Aspirant
mangrove
It's interesting. I thought same thing first but abandoned the idea because it would be very tough to make holes in such steel plate without power tools.
By the way, I checked dimensions of screw holes and found that to locate SATA connector of 2.5-inch drive at exactly same place as 3.5-inch drive, two holes in the connector side will be half covered by tray (pic).
So, if I do the same as you did, the connector would be 1 or 1.5 mm longer than normal position. It would not make any trouble?
