veehexx
Aug 24, 2010Aspirant
2.5" hdd
i've just bought a new hdd for a laptop, and looking at it's spec - http://www.wdc.com/en/products/products.asp?driveid=685, it seems a 1tb drive is also available - i find this interesting! obviou...
mangrove
Jun 19, 2012Apprentice
emoacht wrote: mangrove
It's interesting. I thought same thing first but abandoned the idea because it would be very tough to make holes in such steel plate without power tools.
By the way, I checked dimensions of screw holes and found that to locate SATA connector of 2.5-inch drive at exactly same place as 3.5-inch drive, two holes in the connector side will be half covered by tray (http://www.flickr.com/photos/35497088@N06/7391031382/).
So, if I do the same as you did, the connector would be 1 or 1.5 mm longer than normal position. It would not make any trouble?
There will be a slight flexing of the circuit board, due to the Readynas' impressively good tolerances :D (a normal drive fits absolutely like a glove). I cannot imagine it being a problem, though, but if you are concerned, you could always file back the front mounting points a little.
The resultant flexing of the board is less than 0.5mm (due to tolerances in the lock lever, etcetera).
