cjmcgee
Jun 10, 2010Tutor
3TB drive compatibility?
I own a ReadyNAS Duo with a pair of 1.5 TB drives. It is starting to get full so I am considering upgrading the drives. I could upgrade to 2TB drives, but that seems like a lot of cost and effort for a 33% increase. So, maybe I should wait for the 3TB drives to come out since they are supposed to come out "in the next few months"; but my questions are:
[list=a:1eyjwahw]
Will the ReadyNAS Duo ever be able to support 3TB+ drives?
If so, what kind of ballpark time frame should I be looking at for how long it will be until a firmware update comes out to support them?
Thanks!
[list=a:1eyjwahw]
Thanks!
- jmirabilAspirantVERIFIED : So this weekend I verified that using SIX WD30EZRS (with WDIDLE3 /s0 set on all six drives in a separate sata system) works in a pro business under 4.2.16 if you factory default with these 6 drives in place. Works well... 13.6 Tb reported on the OLED.
This WD30EZRS drive should be added to the compatibility list with default jumper settings and with the Wdidle3 /s0 note or the runaway LCC's will prematurely destroy the drive.
FYI: this drive has alot of jumper options- Netgear you should also test those, maybe the performance can be enhanced... the test this last weekend I did used the drives in their default jumper config. - rolskiAspirantDefault jumper config being - no jumpers ?
And how did you run wdidle3 - can you do that while the disks are installed in the NAS ?
I have a new Ultra4+ with 4 WD30EZRSDTL's and I'm having trouble getting the 4th disk installed successfully.... - PapaBear1ApprenticeWdidle3 must be run while the drive is connected to the SATA connector on the mb of a PC.
- rolskiAspirantOK, thanks.
