BotanyBay's avatar
Jun 14, 2011
3tb esternal USB hard drives under 4.2.17
Having some difficulty seeing the full 3tb on an external USB hard drive. I just updated the Readynas Pro Buisness from 4.2.5 -> 4.2.17 inorder to use 3TB drives as backup media.
I had expected to see ext4 as an option for formatting these drives in the USB volume drop down and I do not. Additionally the drives are seen as 2047GB rather than some number closer to 3000GB.
I am currently using bare Hitachi drives (HDS723030ALA640) from the HCL so that I can install them in the Readynas at some future date when even bigger drives are available for backup media.
I am using a Bytecc SATA Drive Mate to convert from SATA -> USB 2.0 and then into the Readynas.
The drives function correctly, I have two of them formatted as 2047GB drives and have a complete backup of the readynas (made just before the update).
Is this an issue with the SATA -> USB converter not being up to the task or do I need to perform a full reset of the hardware (i.e. wipe the readynas) to get this functionality?
If it is a problem with this SATA -> USB converter is there a unit which would be expected to work.
I currently have 3 seagate 2TB drives and 3 Seagate 750GB drives installed and everything is working well. Other than not being able to see the full capability of these drives when used as external USB backup media.
Thank you for your help.
ProSupport for Business
