BotanyBay
Jun 14, 2011Tutor
3tb esternal USB hard drives under 4.2.17
Having some difficulty seeing the full 3tb on an external USB hard drive. I just updated the Readynas Pro Buisness from 4.2.5 -> 4.2.17 inorder to use 3TB drives as backup media. I had expected to ...
sphardy1
Nov 04, 2011Apprentice
So the net result of this thread is "3TB external USB hard drives under 4.2.17 = works fine, but requires a SATA-to-USB converter also certified as compatible with 3TB drives if you plan on using a bare HDD"?
