BotanyBay
Jun 14, 2011Tutor
3tb esternal USB hard drives under 4.2.17
Having some difficulty seeing the full 3tb on an external USB hard drive. I just updated the Readynas Pro Buisness from 4.2.5 -> 4.2.17 inorder to use 3TB drives as backup media. I had expected to ...
BotanyBay
Nov 04, 2011Tutor
The only question is if you have to be using 4.2.19 or 4.2.17. I did not manage to obtain a compatable sata to USB converter until after having moved to 4.2.19 but I suspect that either would work.
