BotanyBay
Jun 14, 2011Tutor
3tb esternal USB hard drives under 4.2.17
Having some difficulty seeing the full 3tb on an external USB hard drive. I just updated the Readynas Pro Buisness from 4.2.5 -> 4.2.17 inorder to use 3TB drives as backup media. I had expected to ...
TeknoJnky
Dec 07, 2011Hero
As mentioned, over 2tb support requires GPT partitions.
Unfortunately xp does not support GPT partitions, you must use vista/win7, or linux or mac to partition for GPT.
@ davidarky, if you have an NV+, the nv+/duo does NOT support GPT partitions, so the 3tb+ drives will NOT work.
If you want to backup using the 3tb drive, you will have to attach it to a PC/MAC that is compatible with 3tb drives, then backup over the network to the PC with the usb drive attached.
