blusk06's avatar
blusk06
Tutor
Dec 13, 2012
3TB USB HDD on ReadyNAS Ultra 4 Plus
I have a 3TB Seagate Barracuda ST3000DM001 SATA drive thats in a USB 3.0 bay. When I connect it to my ReadyNAS Ultra 4 Plus with RAIDiator 4.2.22 it is not recognized. dmesg output on the ReadyNAS is below.
I have already returned the drive and got another identical one, same behavior. I am going to try another USB bay today to see if that resolves it. Maybe this is a driver issue. Suggestions?
sd 10:0:0:0: Attached scsi generic sg4 type 0
sd 10:0:0:0: [sde] Very big device. Trying to use READ CAPACITY(16).
sd 10:0:0:0: [sde] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
sd 10:0:0:0: [sde] Write Protect is off
sd 10:0:0:0: [sde] Mode Sense: 23 00 00 00
sd 10:0:0:0: [sde] Assuming drive cache: write through
usb 2-4: reset high speed USB device using ehci_hcd and address 9
sd 10:0:0:0: [sde] Unhandled error code
sd 10:0:0:0: [sde] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
sd 10:0:0:0: [sde] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
end_request: I/O error, dev sde, sector 0
Buffer I/O error on device sde, logical block 0
1 Reply
  • also I have installed parted. when I do a "parted /dev/sde1" it just hangs. "fdisk -l" doesn't even show sde.
ProSupport for Business
