pesektl's avatar
pesektl
3TB Western Digital WD30EFRX compatibility
I recenty purchased a ReadyNas 6 Ultra with 3 Western Digital WD30EFRX drives. They are on the compadability list. I am running OS 4.2.22. When I built my system with 3 of these 3 TB disks using RAID x2, I only get 3.4 TB of space in the volume. I think I should see about 5.8 TB. Does anyone know a fix for this issue? Tech Support is of little help. I have had a case open for almost a week ( Case # 20517410) and they have offered no solution. Frustrated! Tom
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Did you install these disks when running 4.2.15 or earlier?
    Are you able to try a factory default (System > Update > Factory Default in Frontview)?
  • Please be mindful that when prefrom a Factory Default you will lose your data!!!!
  • Resetting the Readynas to factory defaults finally fixed the issue along with using rhe Flex-RAID mode instead of the X-RAID2. This rebuild was much faster than previous attempts using X-RAID2 also. I am convienced that there are problems with the X-RAID2 and these 3TB drives but can't prove it. Since I have 4 disks and wanted RAID5 anyway this isn't a real issue.
    mdgm-ntgr
    I have an Ultra 6 and it works fine with this model disks.
    Most likely you added the 3TB disks on 4.2.15 or earlier where they were not supported and the factory default resolved it.
ProSupport for Business
