lanceorion
Apr 14, 2013Aspirant
4TB compatibility
Another question about hard drives!
The official HCL lists Hitachi 3TB and 4TB Ultrastar as compatible with the new (and indeed old) readynas devices - ie the 102/4 etc.
Does that mean that the 3TB and 4TB Deskstar drives by Hitachi are likely to function OK as well?
I am reluctant to use Barracudas in part due to their poor rep in larger sizes but also their limited 1 year warranty. I plan to run the new 104 with 2 drives initially, either 3 or 4TB each and expand the array to the full 4 discs using the same one initially selected.
Any tips?
Any tips?
- mdgm-ntgrNETGEAR Employee RetiredIt's possible that other drives may work. However so note that NetGear can and will deny support if you use drives that are outside the compatibility list.
- lanceorionAspirantIs there any reason why drives are on the HCL for the Ultra 6 but not for the newer models?
If there is, Netgear hasn't said so.lanceorion wrote: Is there any reason why drives are on the HCL for the Ultra 6 but not for the newer models?
Unfortunately, they don't publish a list of drives that they tested and are known not to work.
