GaRFIELD1
Mar 26, 2013Aspirant
4TB disks on ReadyNas Ultra 6?
I just bought a ReadyNAS ULTRA 6 for a great price of less than USD 600,- including a 2TB Seagate disk. Waste of space with only 1 x 2TB, so need to get some new disks... The plan was to fill it up w...
fifer55
May 22, 2013Apprentice
Here is what I have. Not really the answer you are looking for, but it should give you an idea.
Note that I did a factory reset, then added the drives. FrontView only reports 14TB, but Finder notes over 15 TB.
Here is the proof:
Finally, I am thinking of buying these 4TB drives as they are CHEAP and HGST drives (Hitachi HDS5C4040ALE630):
http://www.amazon.com/HGST-Touro-Deskto ... dp_product
Yeah, you are going to need to do some hacking, voiding the warranty on the external HDD's and they are not on Netgear's HCL, but it looks like they work and comparably priced to the discs that you are looking to buy :
http://www.amazon.com/review/R14S2O23SJ ... _rtr_alt_1
These are my next pruchase to replace my 2TB WD green drives.
Here is the proof:
