GaRFIELD1
Mar 26, 2013Aspirant
4TB disks on ReadyNas Ultra 6?
I just bought a ReadyNAS ULTRA 6 for a great price of less than USD 600,- including a 2TB Seagate disk. Waste of space with only 1 x 2TB, so need to get some new disks... The plan was to fill it up w...
Dagster
Aug 16, 2014Aspirant
StephenB wrote:
2. The main "traps" are the two expansion limits. (a) 8 TB volume growth over the lifetime of the volume and (b) can't cross the 16 TB volume size
3. You can create an XRAID2 volume which is >= 16 TB. But you need to do that with a factory default (wiping your data). You can't expand through the 16 TB limit.
Just need a clarification. With 4 x 4 TB installed there will be no reason to put in dIsks in slot 5 and 6 due to the 16 TB limit?
Dag
