GaRFIELD1's avatar
GaRFIELD1
4TB disks on ReadyNas Ultra 6?
I just bought a ReadyNAS ULTRA 6 for a great price of less than USD 600,- including a 2TB Seagate disk. Waste of space with only 1 x 2TB, so need to get some new disks...
The plan was to fill it up with 3TB disks, but i have seen that the prices on 4 TB disks from Seagate now has dropped drastically and .. why not buy 4TB disks to fill it up with instead?
The model i own is: RNDU6000-100PES - ReadyNAS Ultra 6
Disk i wish to buy is: ST4000DM000 - Seagate Barracuda® 4TB
There are NO 4TB disks on the compatibility list at http://www.readynas.com/?page_id=82
Questions are..:
1. Will it work with 4TB disks?
2. What "traps" might i fall into if i do not buy all 6 at the same time?
3. By reading the forum, there are references to 16TB limits.. and basically no option to set all into one big XRAID2 partition ??
4. What is the advise on memory on the box? should i expand it from the default 1GB which it comes with (If possible)?
Thanks for any help on this guys (and girls)!
  • StephenB's avatar
    It's a volume limit, not a raw drive capacity limit. So space needed for redundancy doesn't count.
    4x4TB with single redundancy xraid2 has a 12 TB volume. You need 5x4TB to get 16.
    4x4TB with dual redundancy xraid2 and an eight TB volume - 6x4TB gets you to 16.
  • To expand on this issue: will the RNDU6000 work with the 6TB WD Red drives?
    I mean to populate it with 6x6TB's in Raid 5... but since the drives didn't exist when the RNDU6000 went EOL there isn't an up to date compatability list...
  • StephenB's avatar
    The drives aren't on the compatibility list, so you wouldn't get support, and Netgear hasn't verified that they are compatible. If you purchased around your September 2011, your warranty would run out in about 3 weeks anyway, so the support might not matter much to you.
    There is no fundamental technical here (assuming the drives are in fact compatible). So it ought to work. If it turned out not to work for some reason (after you've spent the $1800 for the drives) you might have to get an new NAS (for instance RN316) to protect your investment in the drives.
  • Thanks for the reply, appreciate it.
    I was asking the same question in two topics because both topics were relevant to my question and vice versa.
    To be future similar question asking users of service I will gladly point them to that other topic -> http://www.readynas.com/forum/viewtopic.php?f=24&t=2464&p=432215#p432215
    I no longer have tech support so I'll have to chance it. I just wanted a reason not to try it and so far there are none.
    Also, another topic mentioned that any size drive should work on any x86 box as GPT drives are not size limited. They are on ARM boxes though.
    So drives are on order (plus I can return the unused ones anyway).
    I will post my results in the OTHER topic as compatability of these drives are directly applicable to that topic.
ProSupport for Business
