Wildtexaschef
Dec 01, 2014Aspirant
6.2.0 has no manual to download
There is no manual for the new firmware 6.2.0 release. A manual is needed to explain in better detail the new features, how to use them and what they are. I have several question in regards to 6...
mdgm-ntgr
Dec 03, 2014NETGEAR Employee Retired
Well the way we have implemented BTRFS using md raid would make some things different to simply using BTRFS.
https://btrfs.wiki.kernel.org/index.php/FAQ indicates that if you mount a volume with CoW disabled then checksumming is turned off. This suggests to me that checksums do depend on use of CoW, perhaps a bit like how snapshots make use of CoW.
Bitrot protection (well at least our implementation) does depend on CoW. If Bitrot protection is disabled then CoW is disabled.
Snapshots are enabled by default on x86 systems. Snapshots will work when CoW is disabled as has been discussed earlier in the thread.
