Wildtexaschef
Dec 01, 2014Aspirant
6.2.0 has no manual to download
There is no manual for the new firmware 6.2.0 release. A manual is needed to explain in better detail the new features, how to use them and what they are. I have several question in regards to 6...
btaroli
Dec 03, 2014Prodigy
mdgm wrote: https://btrfs.wiki.kernel.org/index.php/FAQ indicates that if you mount a volume with CoW disabled then checksumming is turned off. This suggests to me that checksums do depend on use of CoW, perhaps a bit like how snapshots make use of CoW.
I see... mount options. OK. I get that. And I should clarify that, in my environments, I leave all default filesystem features enabled but selectively disable COW on a sub-folder level, and very selectively. If I only wanted COW enabled on a limited basis, I'd just split the activity off into it's own subvolume (or, in ROS6-speak, folder/share).
