Automan
Dec 17, 2014Apprentice
6.2.0 Power Timer Schedule Not Cleared During Factory Reset
Sorry, if this has already been reported but it would seem if you perform a "Factory Reset" and you had shut down and start up times set that these are not cleared and thus if you power down the NAS i...
vandermerwe
Dec 17, 2014Master
Are you certain the factory default was successful?
After you did the factory default, did your nas power itself off on its own?
I have recently factory defaulted a 316 several times and the power timer was off, spindown off, and WOL off.
