Automan
Dec 17, 2014Apprentice
6.2.0 Power Timer Schedule Not Cleared During Factory Reset
Sorry, if this has already been reported but it would seem if you perform a "Factory Reset" and you had shut down and start up times set that these are not cleared and thus if you power down the NAS i...
chirpa
Dec 17, 2014Luminary
Power Timer is likely set to the hardware CMOS RTC (real time clock). So 6.2.1 fw should attempt to clear this setting on factory defaults.
