Automan
Dec 17, 2014Apprentice
6.2.0 Power Timer Schedule Not Cleared During Factory Reset
Sorry, if this has already been reported but it would seem if you perform a "Factory Reset" and you had shut down and start up times set that these are not cleared and thus if you power down the NAS i...
vandermerwe
Dec 18, 2014Master
I realise they're different systems
What would not make any sense is for the power timer to be set to ON after a factory default on any readynas hardware.
If for some reason it defaults to ON with some arbitrary, Netgear determined, on/off times set; then I think that should be changed.
