Automan
Dec 17, 2014Apprentice
6.2.0 Power Timer Schedule Not Cleared During Factory Reset
Sorry, if this has already been reported but it would seem if you perform a "Factory Reset" and you had shut down and start up times set that these are not cleared and thus if you power down the NAS i...
Automan
Dec 20, 2014Apprentice
No, it is not fixed, the unit will still power on...
Sat Dec 20 2014 8:18:41
System: Antivirus scanner definition file has been updated to '201412200631'.
Sat Dec 20 2014 8:00:49
System: ReadyNASOS background service started.
So it would seem a factory reset in 6.2.1 still does not clear this setting.
Disc spin down setting is cleared BTW, and I will check WOL later today.
