Automan
Dec 17, 2014Apprentice
6.2.0 Power Timer Schedule Not Cleared During Factory Reset
Sorry, if this has already been reported but it would seem if you perform a "Factory Reset" and you had shut down and start up times set that these are not cleared and thus if you power down the NAS i...
mdgm-ntgr
Dec 20, 2014NETGEAR Employee Retired
Disk spindown uses the noflushd package so that is to be expected. Unlike the power timer, disk spin-down doesn't use the hardware CMOS RTC.
