Calder
Jan 18, 2017Guide
6.6.1 did not fix UPS detection problem
Still needed to unplug and re-plug USB cable to UPS after a restart for UPS to be detected. Wed Jan 18 2017 16:51:20 System: New USB UPS detected. Manufacturer: APC, Model: Back-UPS ES 550G, Seri...
JanHussaarts2
Jan 19, 2017Luminary
I'm running 6.6.1 on an Ultra 6. No problems with my APS Smart UPS 1000
mdgm-ntgr
Jan 19, 2017NETGEAR Employee Retired
Your logs show that your UPS is detected fine.
- CalderJan 19, 2017Guide
Yes, after I manually unplugged the USB plug to the UPS at the back of the RN104 and plugged it back in to force a redetection. If I did a power-cycle or a restart now, the UPS would not be detected and I would need to unplug and plug the USB cable again to force it to detect. Hope this makes sense.
- FramerVJan 21, 2017NETGEAR Employee Retired
Hi Calder,
Can you reboot, then save the logs and re-send them. It may give a better overview on what is it doing during boot process.
- CalderJan 22, 2017Guide
Hi FramerV,
I already did...
Fri 2017-01-20 11:41 Pacific Time
RE: To mdgm, From Calder - Re: 6.6.1 did not fix UPS detection problem
Thanks,
Calder
