x8x8x
Mar 23, 2012Aspirant
746 Gb=3TB disk
I have a Netgear ReadyNAS Duo v2 (5.3.4) and hard disk WD30EZRX is reported that has a capacity of 746 gigabytes
x8x8x
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/md2 doesn't contain a valid partition table
Disk /dev/dm-0 doesn't contain a valid partition table
Disk /dev/sda: 801.6 GB, 801569726464 bytes
256 heads, 63 sectors/track, 97071 cylinders, total 1565565872 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sda1 1 1565565871 782782935+ ee GPT
Disk /dev/md0: 4293 MB, 4293906432 bytes
2 heads, 4 sectors/track, 1048317 cylinders, total 8386536 sectors
Disk /dev/md1: 536 MB, 536858624 bytes
2 heads, 4 sectors/track, 131069 cylinders, total 1048552 sectors
Disk /dev/md2: 796.7 GB, 796734570496 bytes
2 heads, 4 sectors/track, 194515276 cylinders, total 1556122208 sectors
Disk /dev/dm-0: 786.0 GB, 785979015168 bytes
255 heads, 63 sectors/track, 95556 cylinders, total 1535115264 sectors
