Natolla
Jan 20, 2017Aspirant
Readynas 4200 and 3TB on USB cradle only 746/801 GB...HELP
Hello...
I have a 4200 here that i need to run with a USB attached 3tb Seagate drive...
It shows me 746 gb availalabe and i am able to format that as well...
But i can't get it to see the full size...
smartctl sees the whole cpacity, but fdisk is not able to get it...
I guess it has something todo with the early version of fdisk that does not know GPT...
But somehow it must be possible...
OS is newest version x.30 and i tried to load parted over ssh but it wont work...
Any one did this before?!
THX!!!!
It might be a limitation of the USB cradle. I have an older USB-2 sata adapter that is limited to 2 TB drives.
But you can't use fdisk for this - it doesn't support gpt. You want sgdisk.
- NatollaAspirant
Hello...
Thx for your response...
I already checked the cradle and it supports up to 4 TB according to the tech support...
Will take a look at sgdisk...
Can you make a litte suggestion how to use?!
Havent heard about that yet...
EDIT: Played around with it but it also just shows me the 746.5 GiB
And somehow it seems that it is not writing the info to the drive...everytime i do the commands it does the same output...
Thx!!
- NatollaAspirant
Hello...Checked around with that tool sgdisk
Here the output that it gives me with the 3TB drive:
CEANAS:~# sgdisk -p /dev/sdg Creating new GPT entries. Disk /dev/sdg: 1565565872 sectors, 746.5 GiB Logical sector size: 512 bytes Disk identifier (GUID): 6D0A9B32-E8E6-4BC7-A565-52F643C7DC27 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 1565565838 Partitions will be aligned on 2048-sector boundaries Total free space is 1565565805 sectors (746.5 GiB)
Smart hinggegen gibt das aus:
CEANAS:~# smartctl -a /dev/sdg smartctl 5.42 2011-10-20 r3458 [x86_64-linux-2.6.37.6.RNx86_64.2.4] (local build) Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net === START OF INFORMATION SECTION === Device Model: ST3000DM008-2DM166 Serial Number: Z5048SJ5 LU WWN Device Id: 5 000c50 0a1bc1021 Firmware Version: CC26 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Device is: Not in smartctl database [for details use: -P showall] ATA Version is: 8 ATA Standard is: ACS-2 (unknown minor revision code: 0x001f) Local Time is: Fri Jan 20 13:33:59 2017 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled
