Natolla
Jan 20, 2017Aspirant
Readynas 4200 and 3TB on USB cradle only 746/801 GB...HELP
Hello... I have a 4200 here that i need to run with a USB attached 3tb Seagate drive... It shows me 746 gb availalabe and i am able to format that as well... But i can't get it to see the full ...
Jan 20, 2017Guru - Experienced User
It might be a limitation of the USB cradle. I have an older USB-2 sata adapter that is limited to 2 TB drives.
But you can't use fdisk for this - it doesn't support gpt. You want sgdisk.
Natolla
Hello...
Thx for your response...
I already checked the cradle and it supports up to 4 TB according to the tech support...
Will take a look at sgdisk...
Can you make a litte suggestion how to use?!
Havent heard about that yet...
EDIT: Played around with it but it also just shows me the 746.5 GiB
And somehow it seems that it is not writing the info to the drive...everytime i do the commands it does the same output...
Thx!!
- NatollaJan 20, 2017Aspirant
Hello...Checked around with that tool sgdisk
Here the output that it gives me with the 3TB drive:
CEANAS:~# sgdisk -p /dev/sdg Creating new GPT entries. Disk /dev/sdg: 1565565872 sectors, 746.5 GiB Logical sector size: 512 bytes Disk identifier (GUID): 6D0A9B32-E8E6-4BC7-A565-52F643C7DC27 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 1565565838 Partitions will be aligned on 2048-sector boundaries Total free space is 1565565805 sectors (746.5 GiB)
Smart hinggegen gibt das aus:
CEANAS:~# smartctl -a /dev/sdg smartctl 5.42 2011-10-20 r3458 [x86_64-linux-2.6.37.6.RNx86_64.2.4] (local build) Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net === START OF INFORMATION SECTION === Device Model: ST3000DM008-2DM166 Serial Number: Z5048SJ5 LU WWN Device Id: 5 000c50 0a1bc1021 Firmware Version: CC26 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Device is: Not in smartctl database [for details use: -P showall] ATA Version is: 8 ATA Standard is: ACS-2 (unknown minor revision code: 0x001f) Local Time is: Fri Jan 20 13:33:59 2017 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled
- StephenBJan 20, 2017Guru - Experienced User
So you've resolved this now?
Not at all...
And sorry for the german infront of the second Quote...sometimes i fall back to home...smile
I have not the slightest idea why it is only showing/detecting these 746 gib...
The smart shows the drive and its size correct, but not the protition tools i tried so far...
fdisk failed on it...and your sgdisk is alo not able to see the bigger drive...
Even that it seems to unerstand GPT...
Is there any tool, that can do that?!
Or is there a way to apt-get any modern packages to this old jessie?
