towns
Sep 29, 2022Aspirant
accessing admin page Ready Nas pro 6
Hi - am hoping someone can help please...i am running a ReadyNas Pro 6 and havent updated anything for probably a few years (bad i know) Am running a MAC OS Catalina Ethernet Cable connected to sam...
Sep 29, 2022Guru - Experienced User
towns wrote:
downloaded Firefox and logged into admin page - all good and dont see any network settings that are incorrect or any errors.
Did you download the full log zip file as I suggested?
I am thinking there are disk problems (despite the summary status you are seeing in RAIDar and Frontview). SMART stats are in disk_smart.log, other errors would be in system.log and kernel.log
towns wrote:
but my copy time for 25 Gb is still around 5 hours - dosent seem right?
FWIW, this does depend on what you are copying. A folder full of small files will take a lot longer than a 25 GB file.
Also,is this just an estimated time, or did you actually let it finish?
towns
Sep 30, 2022Aspirant
i looked at the logs under status logs there was no option to download - i saw no errors
where do I find system.log and kernel.log when accessing admin page at https://192.168.1.21?
i cant get RaidAR to work - when i click on admin page from RaidAR screen I just get a blank screen showing ready nas'
dir copied has lots of 30Mb files - 13Gb took 5 mins just now so that seems ok..
thanks
- StephenBSep 30, 2022Guru - Experienced User
The log zip file has a lot more information than the web interface shows. Click on download logs.
