rhabbott
Jun 04, 2010Aspirant
Accessing USB drive with Linux
I have a NV+ with external USB drive formatted in EXT3 where backup is copied to this drive. Power supply crapped out in NV+. :-( Plugged the USB drive into a Linux system (Fedora 9) which should...
xevious
Jul 03, 2011Aspirant
Experiencing same error, any ideas of a fix?
Snow Leopard, 1.5tb hd from ReadyNAS Ultra 6, 4.2.13, XRaid-2.
koikoi wrote: When doing this on my Mac I keep getting this error:
fuse-ext2: version:'0.0.7', fuse_version:'27' [main (../../fuse-ext2/fuse-ext2.c:324)]
fuse-ext2: enter [do_probe (../../fuse-ext2/do_probe.c:30)]
fuse-ext2: Error while trying to open /dev/disk3 (rc=2133571347) [do_probe (../../fuse-ext2/do_probe.c:34)]
fuse-ext2: Probe failed [main (../../fuse-ext2/fuse-ext2.c:340)]
Any idea on what goes wrong?
