rhabbott
Jun 04, 2010Aspirant
Accessing USB drive with Linux
I have a NV+ with external USB drive formatted in EXT3 where backup is copied to this drive. Power supply crapped out in NV+. :-( Plugged the USB drive into a Linux system (Fedora 9) which should...
djepyon
Sep 08, 2011Aspirant
I have the same issue. My ReadyNAS went "corrupt root" on me and I attempted to do this to pull the data off.
One thing you'll notice is that there is no partition on your mounted disk (and its the same with mine). The example says "disk2s1", so a partition is required. You've entered "disk3" -> this has no partition information.
Either there is some issue with fuse where it doesn't show the parition, or the ReadyNas corrupted the partition so it can't be read.
