ranko1
Sep 17, 2011Aspirant
Adding 6x 2TB disks to a Ultra 6....
Hi there, Just bought myself a diskless Netgear ReadyNAS Ultra 6, I'm going to add (initially) two Samsung HD204UI Spinpoint F4 drives, and then a week later, a further 4 drives (same make and mode...
yoh-dah
Sep 18, 2011Guide
yoh-dah wrote:
ranko wrote: Will I need to reboot the3 NAS after inserting each disk so it recognises the extra space?
I guess I cant put all 4 extra disks in, in one go then :(
You can power down, add 4 disks, and power-on. The expansion on the 4 disks will take place on boot. If you want dual redundancy, add 3 disks first, and then enable the dual redundancy option in FrontView before adding the last disk.
Alternatively, if you don't have data on it, it'll be quite a bit faster just factory-defaulting with the 6 disks.
