ranko1
Sep 17, 2011Aspirant
Adding 6x 2TB disks to a Ultra 6....
Hi there, Just bought myself a diskless Netgear ReadyNAS Ultra 6, I'm going to add (initially) two Samsung HD204UI Spinpoint F4 drives, and then a week later, a further 4 drives (same make and mode...
ranko1
Sep 19, 2011Aspirant
Thanks, I might do just that TBH :)
I have a question about the dual NICs, can I connect both onto the same network? Would I gain anything from doing so?
If it doesnt have teaming or failover/load balancing out the box (as its non pro), can it be added via a 'community addon' it is after all only a Linux/*nix OS. :)
