teddis's avatar
teddis
Apparently automatic volume capacity not working as advertised
I'm trying to upgrade from a 8TB to a 16TB system. A year or more ago I bought a 4TB drive as a test and somehow got the system to replicate to it. I wasn't ready at the tim to make the full upgrade, but recently commiting to do so last week. I bought 3 more 4TB Ironwolf COMPATIBLE drives and attempted my first swapout the other day but so far nothing is going as expected. Instead of remaining online but degraded, my volume cage UI went dark and there's no indication any replication is happening. In fact, the system decided it could handle the situation and shut down by itself! Just prior to the swap, I also completed disabled my auto backups. Maybe one clue is an error unable to download firmware, buy why? My system firmware is already install latest of 6.10.5. Seems like a complete bust for a "simple" RAID system upgrade. Are there any diagnostics to check or logs? (Apparently having massive difficulty uploading screen shots here). I can see while editing but then missing after editing.
  • StephenB's avatar
    I suggest testing the new disks in a Windows PC using Seatools. You can connect them either with SATA or with a USB adapter/dock.
    • teddis's avatar
      teddis
      I don't have access to a PC, just my Macs. I've ordered an adapter to test with Disk Util. I replaced the first ironwolf with a second one received but some results. Nothing. The volume cage is dark and doesn't look like anything is replicating. With two such failures, doesn't seem like a shipping fluke, but some odd incompatibility readynas os. I would this this would mount!
      • StephenB's avatar
        Lots of people use Seagate Ironwolf drives, so it's not an incompatibility.
        It's not that uncommon for drives to be damaged in shipment (and if the package is mishandled, it's quite possible that it would affect all the drives in the package).
        Another option is simply to exchange the disks, and see if the second set behaves differently.
        While waiting you could also try testing them in the NAS.
        1. Power down
        2. remove all the old drives (labeling by slot)
        3. insert one of the new disks (perhaps in bay 2, since bay 1 isn't detecting it)
        4. Power up.
        If the NAS detects the drive, it will automatically do a factory install.  You then complete the setup (doing as little as possible).  Then run the disk test (volume settings wheel on the system->volumes tab).  If that completes with no errors, then the test passed.  When done, destroy the volume (using the volume settings wheel option), power down, and remove the drive.
        This only does a read/non-destructive test, but it still has value.
ProSupport for Business
