sdouek's avatar
sdouek
Guide
Dec 15, 2016
Arghh Nas failure again.
This is for my Ready Nas Business Pro.
After the debacle of crashplan and since my nas was unable to upgrade to the new version I disabled it.
I bought a Seagate 8 TB drive and proceeded to backup my nas.  Was going to do a low level format and re-install,
Back up job 13 (via rsync) share: users ran but i notice I put a "/" in the backup job i.e. USB_HDD_4/users so I cancelled it and it took a while to cancell and then replace the "/" iwth a "\" and it ran fine but I notice when I did a df -h my memory space was at 50%.
I next ran backup job 14 and got ambitious and decided to backup my entire share: media,  about 5 TB, this ran for a while and then my wife was unable to copy data over so I checked the backup and it was running fine all though logs exceeded maxumum log space and were truncated.
So I ssh into box and checked and did a df-h and it was at 100%. I tried cancelling job and it did not cancell I also tried to do a system shutdown and that did not work I waited a bit to see if the commands where being delayed.
In the meantime I tried to shutdown my dlna and couldn't so I coppied down the file to my local pc and I delete "files.db" to make space "170 mb".
In the end I had to do a hard shutdown by pressing the on/off button and when it rebooted all of my configurations were gone (the shares were there bu I could not access them) and was unable to add or delete anything via frontview.
I tried to ssh into box but couldn't.
Any help would be apprceiated.
  • I'm not a fan of the Backup solutions built into the ReadyNAS.  They seem pretty primative and you can't trust them.  I had a bad HDD I guess that I was backing up to, and not once did the software say there was any problem.  So I ended up losing Data.  Makes kind of a worthless backup, wouldn't you say?
    I hear support won't help you if you SSH into your NAS.  The last you you ever want to do on a NAS is a hard shutdown, especally while it's busy doing something. That's a good way to screw things up.   I have a Seagate 8TB Backup drive myself and need to get a second one.  The Backup I did on that one turned out fine.  I format to NTFS now just for the simple fact I can pop the drive into my PC system and easily read it. The btrfs format I won't use now as I don't have any way to read it other then through the NAS.   I still need to find a better backup solution then the crap backup software built into the ReadyNAS.    It doesn't do the most basic things like make sure there's enough space to backup to!!!  You basically have to manually figure out how much space each directory is going to take up, add it up and make sure it doens't go over the space you have on your backup hard drive.  i mean really???     Just one of a number of dumb things it doesn't do or I can't figure out.  If I can't figure it out, it's much to complecated for a normal person.
    Hopefully someone here can help you.  You can try calling Netgear Support and see if they can fix things.  It won't hurt to try.
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      Whatever solution you use for backup with any device you should verify from time to time that it's working well.
      You should also have multiple backups so if there is a problem with one you can use the other.
      Using USB HDDs the inevitable failure of disks at some point is a problem.
      It's standard practice for a backup device to be configured to hold more storage than what it is backing up.
      There are other options than backing up to a USB disk e.g. backing up to another ReadyNAS.
      • JBDragon1's avatar
        JBDragon1
        Virtuoso
        Well I have over 13TB on my NAS.  The largest HDD I know of is 10, so kind of hard to do that.  So I have a 8TB HDD and 3TB HDD that I used.  The new 8TB was fine, the 3TB seemed to have issues. Yet not a single error message which backing up to it.  To me that's a pretty big problem and seems to be a basic feature any halfway decent backup program would let you know.
        How many backups do I need?  How about I had 5 backups and 1 drive out of all 5 of those backup's were bad and yet not a single time the NAS told me there was any problem.  What then?    Again, the backup software seems really primative to backup software I've used 20 years ago.  It really shouldn't be this complecated.  I shouldn't be told all is good when it's not and then try and restore the next day and it's mostly garbage.  It makes no sense.  It's pointless for the NAS to spend hours backing up data to a HDD that has issues and then doesn't inform anyone of those issues.  It formated just fine, it Backed up just fine and that is what it showed.  So it's a big fat liar.  How can anyone trust that?  I can't!!!
        I can't see how spending a bunch of money to backup to another ReadyNAS fixes anything other then spending a bunch more money.  It's the same backup software.  That's a single backup and you're just telling me I could have more then that.    How do I verify a backup on a backup I did the day before?   Do I now manually check each and every file myself.  All thouands of them?  For some reason the backup software can't verify what the hell it's doing, that's clearly the case.  It's just blindly copying.  If it fails, it doesn't care, it doesn't tell you, it keeps on going.  One bad copy after another bad copy until it's finished and tells you all is well.
ProSupport for Business
