owngoal
Mar 22, 2013Follower
Bad disks detected and blinking blue LED
Hi, I have the ReadyNas Duo with 2 off 2TB WD Green Caviar drives. This is setup as a mirror. The problem started when the fusebox tripped in the house and the NAS lost power. When I switched the N...
May 26, 2013Guru - Experienced User
Try linux reader to get the files off (http://www.diskinternals.com/linux-reader/)
Also check the SMART stats on your PC for the drive. Acronis disk monitor will show them.
