owngoal
Mar 22, 2013Follower
Bad disks detected and blinking blue LED
Hi, I have the ReadyNas Duo with 2 off 2TB WD Green Caviar drives. This is setup as a mirror. The problem started when the fusebox tripped in the house and the NAS lost power. When I switched the N...
May 26, 2013Guru - Experienced User
Both disks might have failed - several studies have found that multiple drives fail in RAID arrays more often then random chance would predict.
Anyway, I'd try linux reader first (on drive 1), and make a backup if possible before trying vandermerwe's procedure. I agree with the advice to get a UPS.
