BALR1415
Feb 24, 2013Aspirant
Best method to upgrade 2nd disk in Duo V2
I think this should be a simple procedure, but I am asking all the same ...just to be sure. I have a ReadyNAS Duo V2 with the latest firmware (5.3.7). I started out with only 1 WD Red 2TB disk, and ...
de_niro
Feb 25, 2013Guide
sounds most thing is right,but I don't understand why your second 1TB drive would resynced with a 2TB drive,are you sure current volume is redundant and it is running in Xraid mode?
