BALR1415
Feb 24, 2013Aspirant
Best method to upgrade 2nd disk in Duo V2
I think this should be a simple procedure, but I am asking all the same ...just to be sure. I have a ReadyNAS Duo V2 with the latest firmware (5.3.7). I started out with only 1 WD Red 2TB disk, and ...
BALR1415
Feb 25, 2013Aspirant
I checked again today. Dashboard says: X-RAID2 (Redundant) capacity 913.4 GB. Info tab has green lights for both 931 GB and 1863 GB drives.
I might have done a factory reset, don't remember.
When I remove the 1TB Barracuda and insert the new WD Red 2TB I may also do a factory reset. There is not a lot of data on there at this time and I can copy what I need back to the NAS from the Barracuda.
