BALR1415
Feb 24, 2013Aspirant
Best method to upgrade 2nd disk in Duo V2
I think this should be a simple procedure, but I am asking all the same ...just to be sure. I have a ReadyNAS Duo V2 with the latest firmware (5.3.7). I started out with only 1 WD Red 2TB disk, and ...
chirpa
Feb 25, 2013Luminary
You don't need to shutdown in between. Pop out the 1TB, put the 2TB in that drive tray, and re-insert it. The system is hot-pluggable, power down is not needed to swap drives.
Also, you have a Duo V1, not V2. Ignore the label on the bottom, that should really say V1H2 (version 1, hardware revision 2).
