ZBoater
Apr 14, 2015Aspirant
Biggest drive on Duo still 2TB?
Even unsupported? I have an old Duo with 2x2TB HDs and was wondering if 3 or 4TBs would work. Was planning on using is as a backup to my RN202 NAS.
Apr 15, 2015Guru - Experienced User
rsync is computationally challenging for the duo.
The fastest way to migrate your data to the duo is to use NFS with frontview backup. Then edit the backup job, and change the protocol to rsync. Then run it again (the second pass should be extremely fast).
That gives you the fastest speed for the initial transfer, combined with the greater efficiency of rsync for incremental backups.
dstern350
Aug 30, 2015Aspirant
If I already have 3TB drives, cant it just ignore the last TB?
- mdgm-ntgrAug 30, 2015NETGEAR Employee Retired
No
- StephenBAug 31, 2015Guru - Experienced User
Not on internal drives. It might be possible to manually partition an external drive that way (using MBR)
- bassrickSep 18, 2015Aspirant
I have a ReadyNAS Duo model RND2150-100NAS. Per the compatibility charts a Seagate Barracuda, model ST3000DM001 is compatible in my device. However, it keeps showing up as a DEAD drive in my FrontView. Anybody know why it is listed as workable, but doesn't work?
- StephenBSep 18, 2015Guru - Experienced User
The duo v1 does NOT have any 3 TB drives on the HCL. I think you are confused on the model number.
In most cases, a 3 TB is recognized, but only shows up as ~768MB of space. So I'm not sure why it shows up as "dead", but it won't work for sure.
To see the duo v1's HCL list, first pick "legacy", then "ReadyNAS Duo" (http://kb.netgear.com/app/answers/detail/a_id/20641/~/hardware-compatibility-list-hard-disks).
A duo v2 would run 5.x.x firmware - more details are here: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/ It has a -200NAS part number.
