gpwolfe's avatar
gpwolfe
Boo-Yah! 8GB (2x4GB) works in pro.
Greetings,
I just wanted to say that the pro (rndp6000) works w/4GB DIMMs.
Specifically, at least, these:
DDR2 8GB (2x4GB) PC6400 800MHz PATRIOT PSD28G800K
Frontview shows:
Firmware: RAIDiator 4.2.15
Memory: 8064 MB [6-6-6-18 DDR2]
I booted the thing just to see if it'd recognize any of it and grab some logs. Now it's running the memory test. I'll let that go overnight.
I was reticent to try it as no one else on here seemed to think it would work. I looked up the stats on the Q963 controller and ran a few information gathering tools like:
    dmidecode
    hwinfo
    decode-dimms (After building and inserting the eeprom module)
    lshw
And after seeing this:
Memory Controller Information
Error Detecting Method: 64-bit ECC
Error Correcting Capabilities:
None
Supported Interleave: One-way Interleave
Current Interleave: One-way Interleave
Maximum Memory Module Size: 4096 MB
Maximum Total Memory Size: 16384 MB
Supported Speeds:
Other
Supported Memory Types:
DIMM
SDRAM
Memory Module Voltage: 3.3 V
Associated Memory Slots: 4
0x0009
0x000A
0x000B
0x000C
Enabled Error Correcting Capabilities:
None
I figured since it claims to support 4GB modules it was worth a shot.
Here's the 'meat' from decode-dimms with the new memory installed.
Decoding EEPROM: /sys/bus/i2c/drivers/eeprom/0-0050
Guessing DIMM is in bank 1
---=== SPD EEPROM Information ===---
EEPROM Checksum of bytes 0-62 OK (0x34)
# of bytes written to SDRAM EEPROM 128
Total number of bytes in EEPROM 256
Fundamental Memory type DDR2 SDRAM
SPD Revision 1.2
---=== Memory Characteristics ===---
Maximum module speed 1600MHz (PC12800)
Size 4096 MB
tCL-tRCD-tRP-tRAS 6-6-6-18
Supported CAS Latencies 6, 5, 4
Minimum Cycle Time (CAS 6) 2.5 ns
Maximum Access Time (CAS 6) 0.4 ns
Minimum Cycle Time (CAS 5) 3 ns
Maximum Access Time (CAS 5) 0.45 ns
Minimum Cycle Time (CAS 4) 3.75 ns
Maximum Access Time (CAS 4) 0.5 ns
---=== Manufacturing Information ===---
Manufacturer Patriot Memory
Manufacturing Location Code 0x02
Part Number PSD24G8002
Manufacturing Date 2010-W38
Assembly Serial Number 0xB2151B28
Decoding EEPROM: /sys/bus/i2c/drivers/eeprom/0-0052
Guessing DIMM is in bank 3
SPD Revision 1.2
Size 4096 MB
Assembly Serial Number 0xC9131B28
Here's
hwinfo --memory
output:
01: None 00.0: 10102 Main Memory
[Created at memory.61]
Unique ID: rdCR.CxwsZFjVASF
Hardware Class: memory
Model: "Main Memory"
Memory Range: 0x00000000-0x1f3791fff (rw)
Memory Size: 8 GB
Config Status: cfg=new, avail=yes, need=no, active=unknown
Not certain what else anyone might want for added 'warm and fuzziness' to take the plunge.
On another note, the corsair XMS2 twin2x4096-6400c5c did not work for me contrary to many other posts claiming they do. I will qualify that a bit further by stating that I could not get either DIMM to boot in the first socket. The one closest to the cpu. If I put one in the other socket and nothing in the one closest to the cpu it booted fine. If I left the 1GB stock in its shipped socket (closest to the cpu) and put one of the corsair modules in other socket it would boot and show ~3GB - 128MB (shared video ram reservation?).
In any case I robbed some memory out of my son's machine. A pair of supertalent T8UB2GC5 modules also DDR2-800 PC6400. They show up as [4-5-5-15 DDR2] in frontview.
I hope that's helpful.
Thanks,
--Gary
  • If you already have a pro 6, the easiest way to find out what ram is already in the device (google the part number or whatever is printed on the dimm), then google for the same or similar in the size you want.
  • So the RNDP6000-200 only works (unsupported by Netgear) with DDR2 240pin 6400?
    DDR3 is was cheaper than these aforementioned DIMMs
    80+ per module.
    That's your best bet. Even then, a 6400 speed DIMM might not work. I went through a couple models before finding one that wokred. Just make sure wherever you buy it from has a good return policy if you venture off on your own.
    80+ per module.
    That's because DDR3 is the standard now and are manufacturered in larger quantities. A year or so ago it was reversed.
  • Just upgraded the DDR in my Pro6. Piece of Cake. Can't say I see any performance increase, as I never booted with 1GB.
    Here are some photos for anyone curious.
    Pro6 Included 1GB Ram:
    http://www.box.com/file_embed_preview?e ... lor=FFFFFF
    Patriot 8GB DDR2 (Retails $100-150 PSD28G800K PC2-6400)
    I purchased here:
    http://www.frys.com/product/6416292?sit ... IN_RSLT_PG
    Inside of NAS
    I purchased here:
    Inside of NAS
    I can confirm the Patriot PSD28G800K is working fine, just mounting it in my NAS and no problem for the moment.
  • Just bouncing on this old thread here, but do you have to run the memory test when you upgrade your memory for the machine to boot? I tried 2x4GB PC-6400 on my Pioneer Pro and it just lingers on the Readynas logo.
    TIA
  • Likely those modules are not compatible. If it doesnt get past the logo, the memory test won't even work (failed to POST). Does it boot with one stick installed?
  • Thanks, Chirpa. I will try with one module tonight and see if I have better luck. Do you know if I should use one slot over another when using one DIMM?
    ** UPDATE **
    Well after some more testing it does look like this memory is indeed incompatible. I couldn't get it to boot with either stick in the slot furthest from the CPU which, according to Gary's first post, should offer the best shot at getting it to work. I wish I could isolate what makes that Patriot memory work, but I'm just not that much of a hardware enthusiast.
    I was hoping to avoid dropping ~$200 on the Patriot memory since that would make it applicable for Sander's first law of hardware upgrades which states the failure the overall system increases exponentially with each expensive upgrade specific to said hardware, but I guess I will have to swallow that pill if I want to use this system as a home lab.
  • Just to add to those looking for compatible memory for their pro...
    I threw in 2 4GB sticks of Hynix PC2-6400 HMP351U6AFR8C-S6
    It's been working like a charm for a little over a month now... I use crashplan on my box so it's very resource intensive.
