alexofindy's avatar
alexofindy
can data be recovered from a single failed drive?
The question is almost, but not quite, as dumb as it sounds.
I have an Ultra 6+ with a single x-raid-2 volume comprised of four 3TB drives.
One drive failed, and is no longer recognized by the Readynas, or several computers I tried. It spins, but can't be accessed, and therefore can't be erased.
I replaced the drive, and my data is fine, and my volume once again redundant.
My question is this: I have some degree of concern about data security. Can I safely return the failed drive to the manufacturer (Seagate) under the warranty, and not worry about data security? That is, can any useful data be recovered from a single drive of a X-raid-2 array?
  • 4 drives means raid 5 right ?
    As far as I know raid 5 is totally unrecoverable if you have more than one drive failing. If you have four drives they'll have about 1/3 of you data (the fourth drive being a backup).
    So what they'll have is that equation : x+y+z=s
    I know how to retrieve the value of any of those letters from the three other ones, if you don't have the other values I don't see how you can do it. Let's say the disk you give them contains the value 20, it can be 1+1+18 or 7+7+6 or 5+5+10. So as far as I'm concerned, except if this was written sequentially, and I believe only JBOD does this, data is unrecoverable.
    They also are not interested in your data, unless you are really famous, imagine the number of drives they have to inspect each day. I think they'll just plug the disk, check there is no sign of bad treatment and trash it right away. I also think they have a non-disclosure agreement which is pretty automatic in many jobs nowadays, so even if they did retrieve data, they wouldn't be allowed to use it anywhere.
    Unless I missed something (which is always possible) I don't think you put your data at risk sending them only this drive. if you were to send them 3 drives out of four however...
    When you say that the drive isn't recognized, does that mean that you can't see any partitions on it, or does it mean that the computers aren't even aware that it's been connected? If your computers can see that the drive is present, it might still be erasable using the ATA "Secure Erase" or "Enhanced Secure Erase" commands; the easiest way to try that, if you can spare $5, is to download Parted Magic: https://partedmagic.com/
    Seagate's "Media Sanitization Practices During Product Return Process" document:
    https://www.seagate.com/files/www-content/support-content/warranty/_shared/masters/SeagateMediaSanitizationPractices%2005-Oct-2011%20FINAL.pdf
  • StephenB's avatar
    xeltros wrote:
    ...As far as I know raid 5 is totally unrecoverable if you have more than one drive failing. If you have four drives they'll have about 1/3 of you data (the fourth drive being a backup).
    So what they'll have is that equation : x+y+z=s...
    Not exactly - and it depends on what you mean by "recoverable". Mdgm's equations should not be taken literally :D
    RAID-5 with 4 drives uses block striping. Blocks are grouped into 3 data blocks and one parity block (one placed on each drive). The data blocks are not mathematically coded. The parity block is the XOR of the other 3.
    On SPARC v1 units (which use hardware raid), all the parity blocks are organized onto drive 4 - on the so-called "parity disk" (sometimes this arrangement is called RAID-4 btw).
    The other ReadyNAS (which use software RAID) distribute the parity blocks evenly across the 4 disks. You can see a picture here: http://en.wikipedia.org/wiki/RAID if you scroll down.
    In this case we are talking about an ultra, so the parity is distributed. Each disk in the volume set holds 1/4 of the data blocks (perfectly recoverable) and 1/4 of the parity blocks (not recoverable). The recoverable portion is 2.25TB of the total 9 TB volume, the parity is the other 0.75 TB. Sorting out what these datablocks contain would be difficult, but one could search them for data patterns, etc. The attacker wouldn't know the parity organization, but can simply search those blocks along with all the rest.
    I think the risk is fairly low, particularly with an RMA to the manufacturer. Generally I attempt to zero the drive with the manufacturer's diags before returning (actually seagate's write zeros test works on WDC drives, and vice versa). Though if the drive failure prevents that, I don't worry about it. One reason for the zeroing is that it often does fail, and gives me an error code for the RMA.
    The ATA secure erase command is available on all drives manufactured after 2001, so it is another option. If the drive is hardware-encrypted, then the enhanced secure erase command is extremely fast (it just changes the encryption key). Otherwise, it commands the drive to overwrite every sector. BTW, third party programs to overwrite the drive are not better than this (and are generally less effective) - there is a tutorial here if you are interested: http://cmrr.ucsd.edu/people/Hughes/docu ... torial.pdf
ProSupport for Business
