eclark
Apr 27, 2016Aspirant
Can I have two ReadyNas 316 (or another model) systems auto back up to one another?
Hi! I am a professional photographer and we are looking for a streamlined solution for our photo and video backup. I would like to have one ReadyNas system at my studio and then have it both back...
Apr 27, 2016Guru - Experienced User
It is possible. You can use replicate to back up to the system at your house.
There are a couple of options to back up to the cloud. What make sense there depends on what cloud service you are talking about. I use crashplan on my pro-6 - that needs to be manually installed with ssh and requires some linux knowledge. Though you can alternatively install crashplan on a windows-10 system, and mount the NAS volume as a network drive - backing up the NAS through the windows 10 system.
Amazon Cloud sync is in beta, I am not sure if it is ready to do what you want yet.
You could also use Egnyte, you'd need to contact them for pricing. But it looks like you'd get 10 TB of cloud storage with a single-employee license for $15 per month.
JennC
Apr 27, 2016NETGEAR Employee Retired
Hello eclark,
Welcome to the community!
There are 2 options, backing up using rsync protocol which backs up one system to another locally or the ReadyNAS Replicate that needs Internet.
Here are the article you may want to see and read:
How do I back up data between two ReadyNAS OS 6 systems (using the backup manager)?
How do I back up data between two ReadyNAS OS 6 systems (using ReadyNAS Replicate)?
